VCS WEB INTERFACE ISSUE
Hossam Al-kurdi
DEARS,
I'M trying to access my VCS web interface but all i get is a blank page  everytime  i put the user name and password .though i can manage to access through SSH and i've put some command to remove the certificatation authentication ( if the problem caused by the certificate authintication ) but still nothing happens please please please advice
18 Replies 18
Thanks Martin,
i'll give it a try and let you know how i go
cheers
Vu
am i missing something? i followed the above steps but still can't get to my VCS Control via the web interface.
i am currently running VCS x8.1
steps i took:
1. Connect to the VCS as root via Secure Shell (SSH).
2. entered - echo "SSLVerifyClient none" > /tandberg/persistent/etc/opt/apache2/ssl.d/removecba.conf
3. manually removed the removecba.conf file using;
     rm -i /tandberg/persistent/etc/opt/apache2/ssl.d/removecba.conf
4. tshell
5. restart
6. tried to connect to the VCS via the web interface but unsuccessful.
Is there another approach i can take?
cheers
Vu
I think you need to do a reboot between steps 2 and 3.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Tried all of that... but still the same issue, i can't get to step 4 ie web to the VCS control.
does the VCS have to be in maintence mode?
do you have to turn https off first?
kind regards
Vu
