VCSc and VCSe
David Mowery
I am super-confused about VCSc and VCSe licensing and entitlement. I need to spin up a VCSe but I can't figure out how. Do I need an option key to turn VCSc to VCSe? If so, what is the sku for this key?
Thanks for your help!
2 Accepted Solutions
You install the basic VCS software (common to both), but when you order it you usually order it as either a VCS-C or VCS-E.
SKU for a VM VCS-E is R-VMVCS-EXPWY-K9.  This will give you the option keys to turn your basic VCS install into a licensed VCS-E.
All SKUs for VCS products can be found here: http://www.cisco.com/c/en/us/products/collateral/unified-communications/telepresence-video-communication-server-vcs/data_sheet_c78-626491.html
Martin Koch
First step would be to know if you talk about physical vcs appliances or just virtual sessions.
The physical vcs comes in either a VCS-C or VCS-E version.
Not sure if or how there is a procedure to move from a -C to a -E.
Regards the virtual fresh installation, see Nicks posting.
That said, the ova image you can download is a VCS-C, yes, but it is only a demo mode.
This means for a VCS-C you will need a release key and option keys.
And also here, not sure if there is a procedure if you have a registered VCS-C if there
is an official upgrade path.
Martin Koch
