vedio over ip
miras.pt
My company is going to take mpls vpn connectivity between headquarters and bureau .we have Cisco router to terminate mpls connection in each location. Our main purpose for this connectivity to send video to head quarters which is capture from cameramen.
So I would like to request what configuration we needs to done on HQ and branches, does we need to enable multicasting routing for video in each location
ronpatel
Level 8
Level 8
HI
It all depends on the application you are using.
Below link may give you details for your deployment.
http://www.cisco.com/en/US/docs/video/cuvc/design/guides/srnd/vc5xsrnd.html
regards
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
