02-11-2014 06:47 AM - edited 03-18-2019 02:34 AM
I should provide video conference set , if I install two EX90s at two sites , Is it enough ? to setup conference between those two sites , or I should need server ?
Please , advise
BR
02-11-2014 08:14 AM
It's possible, you could use them as an H323 only device calling directly out. Would need to make sure the appropriate ports are open between the EX90s if there is a firewall in the middle.
02-11-2014 03:08 PM
Hi Ahmed,
As Patrick has indicated, yes, it is possible for two EX90s to direct dial to each other with the appropriate configuration and ensuring all the firewall holes are in place between the sites.
It's not a cheap option though, depending on your requirements for a small installation such as this (unless you're planning on growing it later), you could be better off with PC/Software based solution (www.ciscojabbervideo.com).
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
