VM VCS clustering
Melany Nolan
If I want to build a cluster for VM VCS, what license do I need to buy?
Or just need to buy 2 x R-VMVCS-CTRL-K9 ?
Thank you.
Patrick Sparkman
Both VCSs need to have the same option keys installed, such as provisioning, as they are not shared between the cluster.  The number if call licensees (non-traversal/traversal) and registrations don't need to be the same, as they are shared between the cluster.
I'd suggest you check the VCS Cluster Deployment guide for more details and make sure you have all the prerequisites in order.
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Cluster_Creation_and_Maintenance_Deployment_Guide_X7-1.pdf
6 Replies 6
Patrick Sparkman
Thanks, so I need to have 2 copy of R-VMVCS-CTRL-K9 and the license, right?
Yes would you need to purchase two licenses to activate the VCSs one for each VM in the cluster, plus whatever options and call licenses you'd like to have.  Contact your Cisco rep for some help in purchasing as they can suggest or recommend what to get to best fit your needs.  They can also make sure what you're expecting to buy is all in order and will work as expected.
i recommend to deploy the each VCS VM's on a seperate VM machine's or UCS's. It is not good to make a cluster on the same physical machine :-)
You are right, thanks
Thank You.
