VOIP
adeebtaqui
Level 4
Level 4
For 350 users, which Cisco VOIP solution is better?
Is 3925e voice bundle with cube sufficient for it or BE6000M with an isr better.
Jaime Valencia
This is the Video Over IP community, you should move this to the IP Telephony, or other community.
FYI, if you're a partner, you can reach pre-sales for this question, if not, you should reach a partner to properly size and choose the platform based on your requirements.
java
if this helps, please rate
