Webex Plus Codec - Fix HDMI 3 Monitor Output to Camera Sources
dbeaumont
I am designing a system where we have 2 x Precision 60 Cameras (via a small switch) going into a Webex Plus Codec. The room uses the supplied Touch 10 panel.
The client wants to use HDMI 3 output of the codec to send to a HDMI>USB converter and plug this USB in to a laptop so they can use the cameras as a Webcam for soft conferencing.
My question is can HDMI 3 be fixed to always output one of these cameras, or be able to toggle between these two cameras on the touch panel to send to the Soft Conference device?
Further to that I have another room where they want to use the secondary output of the Quad Camera to the HDMI>USB converter and wondered if there could be scaling issues baring in mind the Quad Camera outputs a much higher resolution.
Are you able to just set SelfView to be used on Monitor 3?
Also, depending on your room size, the Room Kit Mini has a USB interface to allow you to natively use the camera on a laptop/computer etc for other applications.
