factory reset Tandberg C40
laroca
Please your help to help me with a procedure to get factory reset Tandberg C40. I do not know the PW for this device. Thanks
Firstly, you can try the default password for the "admin" user, which is "TANDBERG".
If that doesn't help, you can reset the C40 from the Touch interface, the Web Interface, or using the Serial Interface.
See Page 139 of the Admin Guide.
If you don't know the admin password, and cannot use any of those methods, then you will need to do the following process:
The process to factory reset via the serial com port:
  1. Connect a serial cable to the system at 38400, 8, N, 1
  2. Reboot the system
  3. Log in with the user "factoryreset". This user is only available a short period of time after reboot (in TC6 it is always available). When logging in with this user it is possible to do an xCommand SystemUnit FactoryReset Confirm: Yes
  4. Do a reboot: "XCommand boot"
  5. The system is now factory reset.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
