05-29-2018 11:30 PM - edited 03-18-2019 02:08 PM
Hello.
In our company there is conference system RCF Forum 3000 with microphones. I would like connect this system to Cisco Spark Room Kit Plus. I couldn't find in the data sheet of Spark Room Kit Plus any information about a line input.
Is there any solution for connect external audio source (RCF Forum 3000 in my case) with line output to the Spark Room Kit Plus?
Solved! Go to Solution.
06-11-2018 10:58 PM
The SRK+ doesn't have a dedicated line level input, but you can use one of the three Microphone inputs and adjust the level appropriately. You will however need to use a cable in to the SRK+ that has the correct 4-pole 3.5mm jack on the end of it, not just a standard stereo 3.5mm one.
Please remember to mark helpful responses and to set your question as answered if appropriate.
06-11-2018 10:58 PM
