What is the difference between MCU & Cisco TelePresence Server?
YAARUB F. MILAD
Hello Pros,,
I would like an answer for this question "What is the difference between MCU & Cisco TelePresence Server?" to help us find a solution that best fits our requirements .
also I would appreciate it if you refer to a document that directly discusses the difference in a straight-forward manner.
Thanks for taking the time trying to help ,,
15 Replies 15
What are the advantages of using TelePresence Server and a MCU in combination?
Each has some overlapping capability, but there are a few things that each can do individually that the other can't - so there may be circumstances where you would have both in your environment.
But keep in mind that both are End of Support products so you should probably consider migrating to something more current (like CMS or Webex).
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
