what is the maximum concurrent connection that CMS server HW can handle
ali.nssaif
Hi, we are planning a new cluster that has 3 nodes[HW type is CMS 1000 ], so based on the documents [3K for audio] per server,
Does this mean we have about 9K G711 audio connection [ am taking about HW limit ] for license we are ok to have what is required license
thank you
Yes, as I mentioned, if you're having spaces that are distributed, a call from server to server will be established, and will count against the maximum calls.
java
if this helps, please rate
Jaime Valencia
If you haven't read it, the planning your deployment CMS guide discusses licensing.
Yes, theoretically, you'd be looking at 9K G.711 calls.
If those calls are going to be distributed between the servers, you need to take into account that each call from server to server to join the spaces, is going to count against the maximum number of calls.
java
Hi Jaime ,
Thank you for reply , so if I have once cluster with 3 node and let's assume 5 call bridge 3 in US and 2 in UK , so I am still reaching the 9K g711 on same cluster distributed between those bridges and call between server to server . ?
java
