09-18-2017 02:35 PM - edited 03-18-2019 01:28 PM
Hi, we are planning a new cluster that has 3 nodes[HW type is CMS 1000 ], so based on the documents [3K for audio] per server,
Does this mean we have about 9K G711 audio connection [ am taking about HW limit ] for license we are ok to have what is required license
thank you
Solved! Go to Solution.
09-20-2017 07:15 AM
Yes, as I mentioned, if you're having spaces that are distributed, a call from server to server will be established, and will count against the maximum calls.
09-18-2017 03:40 PM
If you haven't read it, the planning your deployment CMS guide discusses licensing.
Yes, theoretically, you'd be looking at 9K G.711 calls.
If those calls are going to be distributed between the servers, you need to take into account that each call from server to server to join the spaces, is going to count against the maximum number of calls.
09-19-2017 07:24 AM
09-20-2017 07:15 AM
