With the EOL announcment, what product is replacing the SX Series codecs
shawn
What is in line to replace the SX series equipment?  Hopefully there will be more choice as with the C series, and not a one size fits all like the SX80.  The SX series replaced the C series - which in my opinion had a better choice of products to fit the different room/installation size's that we were installing them in.
Justin Ferello
Level 5
Level 5
The replacement should be listed at the bottom of the EoL document. It should either be the Spark Room Kit or Spark Room Kit Plus.
Thank you,
Justin Ferello
Technical Support Specialist, ScanSource KBZ
Justin Ferello
Level 5
Level 5
Thank you,
Justin Ferello
