11-21-2014 05:14 AM - edited 03-18-2019 03:41 AM
Any ideas?
Cheers,
Chris
11-21-2014 02:14 PM
Hi Chris,
kindly find the below Bug id related to your case
https://tools.cisco.com/bugsearch/bug/CSCur11045
Anas
don't forget to rate the helpful posts
11-22-2014 08:16 AM
Thanks Anas, I haven't seen this on the Cisco known bugs VCS Notification.
It also appears that setting the time zone to "Europe/London" corrects the issue. Of course we will see if this works properly next spring when we go to back to BST. I'm not sure why there would be multiple time zones that refer to the same geographical location.
Thankfully, this can be set via a TMS Template option so multiple devices (+70) can be updated at once.
