Showing results forĀ
Search instead forĀ
Did you mean:Ā
audio and video capturing device
JJMANDASSOC1
I'm looking for a audio and video capturing device that will be compatible with jabber.
I'm trying to setup a conference room that already has a analog camera that I can use but I need an device to pull-in the audio through a hard wired or wireless device plus bring the video in  also. I'm using a laptop with win 7 to set this up .
I try one device and shuts down jabber.
Lawrence James
there are a number of options for this now. I have used the solution from Vaddio in about 40+ conference rooms
Vaddio AV Bridge Conferencing
I will be switching to the product from Extron in all future installations that require just due to smaller form factor, easier integration and being Extron dealer better pricing.
Extron Mediaport 200
I have tried cheaper options and other consumer grade products and they have failed or required much more care and support to make the premium price on the pro models worth it it in the long run
