Audio Distribution from Room Kit Plus
mohdshajan
we have a requirement for a fixed volume output from a Cisco Room Kit plus system for hearing augmentation and a variable feed to room's ceiling speakers. The volume is controlled from the Cisco Touch 10.
The analog output shall be used for the variable level control for room speakers, can we separately route audio on the HDMI channel at a fixed level ?
Appreciate your thoughts on how this can be achieved.
I do not believe this is possible - the volume control affects all the audio outputs at the same time - you cannot adjust one without the others.
The other option is to create a separate volume adjustment on your DSP / external Room Audio and not use default the Touch10 volume control.  You could then put a macro on the RoomKit that sets the volume back to the default level every time it is changed just in case someone does try to adjust it with the Touch10.  You could present this additional volume control on to the Touch10 using the In-Room Conttol functionality.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
