Cisco Expressway Cluster Creation and Maintenance Deployment Guide X8.10 - missing?
marco_81
Hi all,
trying to upgrade VCS X8.9 cluster to version X8.10.3. Installation guide suggests reading "Cisco VCS Cluster Deployment Guide", but cannot find any for version X8.10.
So could you share documentation on how to upgrade VCS cluster X8.9 to X8.10.3?
thanks
Must follow Expressway's guide cluster maintenance as per link below?
https://www.cisco.com/c/en/us/support/unified-communications/expressway-series/products-installation-and-configuration-guides-list.html
Would be OK for VCS also?
Jaime Valencia
Documentation is not created for every single release, you can follow the closest one and that will work.
The VCS and expressway documentation is pretty much interchangeable as they both run the same code and right now are almost 100% feature parity.
java
if this helps, please rate
