Cisco TMS 15.11 with SQL 2019
David Anstee
Level 4
Level 4
The newest SQL Server Express release is 2019. In the TMS 15.11 install and upgrade guide updated last month (https://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/tms/install_guide/Cisco-TMS-install-guide-15-11.pdf)  SQL Server 2019 was still not mentioned.  Can anyone please confirm if SQL express 2019 is compatible and supported by Cisco TMS 15.11 please
Jaime Valencia
Documentation lists what IS supported, anything that is NOT listed in the documentation is to be considered as NOT supported.
java
if this helps, please rate
While it is likely that it will be "Compatible", this doesn't mean that it's "Supported".  SQL2017 is the most recent "Supported" version as per the Install Guide you linked.  You can of course deploy it with an unsupported version, but if you encounter any issues, you will not be able to seek assistance from Cisco.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
