CISCO WebEx Codec Plus & Cisco WebEx Control Hub
Malikzm
I'm new to this system and need support. We will going to buy Cisco WebEx Codec Plus TTC7-25, 10 units, and will buy Cisco WebEx Control Hub too for our organization.
I would like to know, do I need to buy separate license for codec plus TTC7-25 along with it or if I'll use control hub, I can add these devices to it and manage/administer them and make conference calls ?
Zahid
Leonardo Santana
You need a Room Device Subscription to register the devices at the Control Hub.
There is discussion here with a lot of info that can guide you
https://community.cisco.com/t5/collaboration-voice-and-video/looking-for-info-on-cisco-collab-solutions/ta-p/3649062
And contact your local partner too.
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
Dear Leonardo,
That means beside getting the Cisco Control Hub Subscription, I must have Room Device Subscription too ?
Yes.
Leonardo Santana
Leonardo Santana
Control Hub is not a license. its the portal which you use to administrate, analyze, configure webex cloud subscriptions, device registration, meetings etc.. .
To register the Device, you need device registrations license. If you subscribe Cloud device registration, you will  get the access to control Hub.
Response Signature
