CMS Recording Web interface
saleem pc
Cisco CMS 1000 with Separate VM for CMS recording v 2.6.1
Recordings are successfully stored in NFS Storage in MP4 format under space folder. However we are recording TMS scheduled meeting, and the space Name is random and difficult for users to find their recordings.
I understand unlike Cisco Media sense or TCS there is no web interface for user to browse the recording and vBrick is a user-friendly interface for recording and streaming. Please correct if my understanding wrong.
Please advice any workaround / steps other than vbrick to have a user friendly web interface similer to Cisco TCS in windows server
Jaime Valencia
That's correct, CMS recorder just dumps the recordings to your NFS if that's all you have configured, and there's no GUI to browse them or watch them.
Aside from creating your own interface, you would need to use vBrick, I know VQ is also used for CMS management, but I'm not sure if they also manage the recordings, you can reach out to them to find out.
You also want to watch the CMS VoAM session to take into consideration a few things that will change
https://community.cisco.com/t5/collaboration-documents/voice-of-the-am-voam-events/ta-p/3648396
The session name shows as Cisco New Immersive GTM, but it's really a CMS update session
java
if this helps, please rate
MrKj
You may also consider using the REC.VC cloud service as an alternative way to record CMS meetings. Free trial is available here: https://my.rec.vc
Cheers!
