08-01-2017 12:36 AM - edited 03-18-2019 01:21 PM
Hi All,
I was going through the CMS deployement guide, and while reading the section 7.1 Lync clients dialing into a call on the Meeting Server.
Ideally will required a lync side configuration and on CMS we should be configuration the incoming call rule and not the outgoing calls right?
because to lync client rech the CMS only incoming call rule will be match is there somthing m missing ?
If we do required a outgoing call rule then what will be its requirement ?
please check page 55
Solved! Go to Solution.
08-01-2017 08:02 AM
In section 7.1 of the guide you linked to, the incoming Lync call matches the domain already configured in the previous chapter in step 6.6.2. It also says to add a Lync static route pointing to the Meeting Server, an example static route is in Appendix C.
If you want the Meeting Server to be able to call out to Lync clients, an outgoing call rule must be added pointing to Lync, see step 7.1.2.
08-01-2017 08:02 AM
08-01-2017 10:35 PM
Thanks Patrick.
So my understanding is correct...but the way cisco has publish the contain if u directly go on section 7 u wont understand.
