Enable HTTP Cisco CTS Codec Codec-PRI-G2
RAMEEZ RAHIM
We want to access the CTS Codec over http without being redirected to https.
Is there a way we can disable redirect or disable https itself.
Any suggestions would be appreciated.
Martin Koch
I only shortly browsed through the documentation but did not find anything regards disabling https or disable the redirect you encounter.
Just out of curiosity, why do you even want to not use https?
Our customer is actually developing a API to poll these codecs.
Unfortunately they still don't support https.
Hi Rameez..
  Since the purpose of https is for security which is default web access protocol for the codec we don't have configuration to disable the https and access the system using http which is unsecure. You can try using SNMP to query the cts codec.
