Migrating VCS-C and VCS-E to AWS
Yan Simkin
Hi all,
We're running our VCS-C and -E clusters on VM's, on prem. Recently sterted thinking of moving these to the Cloud (AWS, specifically). Can't find any info on that. Is this possible at all?
Thanks.
Jaime Valencia
The product documentation, either release notes, installation guide, etc. Contain the supported platforms, what IS LISTED is what IS supported. If you don't see a platform listed, AWS for example, then that means it is NOT supported.
java
if this helps, please rate
Jaime Valencia
java
You need to consider what the device functions are - for keeping local traffic local, and handling firewall traversals - so moving them off-site breaks the whole concept of why they are likely there in the first place.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
