Options for monitoring or retrieving system performance statistics from C-Series, EX-Series codecs
ANDREW BEEZLEY
Hello - I have been looking around to see if there is an option available today to retrieve system performance statistics (such as CPU Load, Memory Load, etc...) from TAA endpoint either via command line interface or via Dynamic XML Poll (http "getxml") from an endpoint.  I understand that Cisco does not have an enterprise MIB available for these endpoints today and that the API is required to pull information from the codec however, I want to be able to pull CPU load and memory load from these endpoints dynamically.  Is there a way to do that today?
Thank you in advance,
-Andrew
Martin Koch
Hello Andrew!
In general this is something I would not really worry about and be more skeptical if the
monitoring itself generate additional load = trouble.
As the systems are based on linux you have command line tools and the proc interface
you can use to get some stats out of the endpoint. I prefer looking at them if there is trouble
rather then trying to do some pro-active stuff, I think thats better handeld via the endpoints.
Example, login as root and try w or free
[Martin-Koch-EX90--ATEA-Vaas:~] $ w
00:17:02 up 14 days, 23 min,  1 user,  load average: 0.00, 0.02, 0.05
USER     TTY        LOGIN@   IDLE   JCPU   PCPU WHAT
root     pts/0     00:03    0.00s  0.31s  0.02s w
[Martin-Koch-EX90--ATEA-Vaas:~] $ free
             total       used       free     shared    buffers     cached
Mem:        510912     309832     201080          0      25768     156616
-/+ buffers/cache:     127448     383464
Swap:            0          0          0
also the proc interface is interesting:
[Martin-Koch-EX90--ATEA-Vaas:~] $ cat /proc/uptime
1210174.87 1193259.96
[Martin-Koch-EX90--ATEA-Vaas:~] $ cat /proc/loadavg
0.00 0.01 0.05 1/131 25905
[Martin-Koch-EX90--ATEA-Vaas:~] $ cat /proc/meminfo
MemTotal:         510912 kB
MemFree:          210312 kB
Buffers:           25580 kB
Cached:           156016 kB
SwapCached:            0 kB
Active:            70892 kB
Inactive:         115896 kB
you should be able to add an ssh key and auto login and get the information you need and
process them via a script and then use that data in your monitoring tool.
and sure you have the xstatus which you can also access via tsh or the http xmlapi, you find more info
about that in the api guide. As you wrote, there is not that much you get out via snmp.
The intention itself is right though, so maybe you could file a feature request for traps
and better pro-active monitoring, major thing I lack the most on C/TC is the lack of traffic/network/loss reports.
please rate answers!
Martin Koch
Hello Andrew!
Swap:            0          0          0
MemTotal:         510912 kB
MemFree:          210312 kB
Buffers:           25580 kB
Cached:           156016 kB
SwapCached:            0 kB
Active:            70892 kB
Inactive:         115896 kB
the codecs are distributed systems, therefore looking at the PowerPC, the central nerve system of the codec running linux, only shows one processor. There are also audio and video DSPs. The commands given above all pertain to the load on the PowerPC. From the DSPs there's indeed not a lot of info one can get, at least I am not aware of any commands to check their load etc.. An additional command to check the central CPU is sys-rtos which you can run from the admin shell.
sys-rtos all
Heap statistics
Total allocated:          9113600 bytes
Allocated and in use:     8229080 bytes
Allocated but not in use: 884520 bytes
Allocated by mmap:        14307328 bytes
*********** RTOS Commands ***********
Options to this command are:
General:
heap           Display heap info
help           Display this menu
RTOS status:
all            Display all RTOS status
ms [name]      Display Mutex Status [mutex name]
qs             Display Queue Status
ss [name]      Display Semaphore Status [semaphore name]
ts [name]      Display Task Status [task name]
CPU load measurements:
cpu adhoc      Display Ad Hoc CPU Load Status
RTOS service routines:
scp pid pri    Change Priority for Task
scs pid sched pri Change Scheduler for Task
src            Retrieve Current Time in Ticks
srt tid        Resume Task (tid = hex (0xn) format)
sst tid        Suspend Task (tid = hex (0xn) format)
stt tid        Terminate Task (tid = hex (0xn) format)
Mutex                Address    Status     #Taken  #Blocked
mutexListLock        0x11d56ca8   locked      135         0
TTPARAMSdbswap       0x11d56c70 unlocked        0         0
cuil_handler_regist  0x11d5c640 unlocked    10006         0
cuilAddNameToNameMa  0x11d5c6b8 unlocked      323         0
cuil_command_mutex   0x11d5c900 unlocked     9925         0
cuilSetLitrValue     0x11d5c938 unlocked        0         0
protectmutex         0x11d7da00 unlocked       36         0
TTOSmutex            0x11d71940 unlocked        0         0
taskListLock         0x11d71bb0 unlocked       37         0
semListLock          0x11d72c58 unlocked        7         0
Option key mutex     0x11d73610 unlocked        6         0
releasekey           0x11d73888 unlocked        0         0
backlightmutex       0x11d738c0 unlocked        4         0
sessionmutex         0x11d73928 unlocked     9551         0
COM mutex            0x11d73978 unlocked        8         0
ledmutex             0x11d8ab40 unlocked        7         0
uhpihostWP           0x11d75e10 unlocked   124567         0
secmodMutex          0x11dad180 unlocked        1         0
GlobalLogLock        0x11dad1e8 unlocked      343         0
MainDBmutex          0x11dad548 unlocked    32787         0
MainDBlist           0x11dad580 unlocked      111         0
StatusHandler        0x11ee8450 unlocked    21511       118
WatchdogLock         0x11f8a0a8 unlocked    47786         0
timersystem_lock     0x11f8ba50 unlocked   717432       110
watchdogclientlock   0x11f8bb18 unlocked    95571       106
pool_0               0x11fa8338 unlocked  1445803       150
pool_1               0x11fa8370 unlocked 11236064       118
pool_2               0x11fa83a8 unlocked     9224         0
pool_3               0x11fa83e0 unlocked     2546         0
pool_4               0x11fa8418 unlocked     9673         0
pool_5               0x11fa8450 unlocked     1514         0
pool_6               0x11fa8488 unlocked      415         0
pool_7               0x11fa84c0 unlocked        8         0
pool_8               0x11d73dc0 unlocked    19122         0
pool_9               0x11d73df8 unlocked        0         0
pool_10              0x11fa8600 unlocked        0         0
globalLock           0x11fb7b20 unlocked        2         0
OutRecvLock          0x11fb7b58 unlocked        8         0
socklib              0x48200890 unlocked        0         0
VidMonAgent          0x4820b720 unlocked        9         0
protectmutex         0x4820db08 unlocked     1571         0
socklib              0x11fd1700 unlocked     7578         5
comrouterRoutingMut  0x11fd1928 unlocked        0         0
TMQueueMutex         0x12302d00 unlocked        0         0
QueueMutex           0x12302e38 unlocked     3183         0
DeleteMutex          0x12302e70 unlocked     1592         0
VidMonAgent          0x123159f0 unlocked        0         0
VidMonAgent          0x123200f0 unlocked        0         0
VidMonAgent          0x1232a7f0 unlocked        0         0
VidMonAgent          0x12334f58 unlocked        0         0
VidMonAgent          0x12334f90 unlocked        0         0
VidMonAgent          0x12334fc8 unlocked        0         0
VidMonAgent          0x12360460 unlocked        0         0
VidMonAgent          0x1236ab60 unlocked        0         0
VidMonAgent          0x12375260 unlocked        0         0
VidMonAgent          0x1237f960 unlocked        0         0
VidMonAgent          0x1238a060 unlocked        0         0
TMQueueMutex         0x1238a288 unlocked        0         0
TMQueueMutex         0x12395730 unlocked        0         0
TMQueueMutex         0x12397dd0 unlocked        0         0
CallLogDBmutex       0x4989ad20 unlocked     4585         0
CallLogDBlist        0x4989ad58 unlocked        5         0
cli_com_mutex        0x1215cfc8 unlocked        9         0
cli_com_a_mutex      0x1239bbe0 unlocked     9922         0
cli_lock             0x1239c4c8 unlocked        0         0
cli_com_mutex        0x1242bc80 unlocked    10277         0
cli_com_a_mutex      0x1242bcd0 unlocked     9965         0
cli_lock             0x1242bfa8 unlocked    19840         0
cli_com_mutex        0x12408360 unlocked       16         0
cli_com_a_mutex      0x124083b0 unlocked      348         0
cli_lock             0x12408470 unlocked        4         0
CuilHandlerGateway   0x123f30e8 unlocked        3         0
VidStreamLock        0x49e271a8 unlocked      744         0
cli_com_mutex        0x1247b1e0 unlocked        0         0
cli_com_a_mutex      0x12403630 unlocked        0         0
cli_lock             0x12403668 unlocked        0         0
cli_com_mutex        0x1246ef38 unlocked        5         0
cli_com_a_mutex      0x1246ef88 unlocked        0         0
cli_lock             0x12408a00 unlocked        6         0
CuilHandlerGateway   0x1247b460 unlocked        3         0
CuilHandlerGateway   0x12438ba8 unlocked        3         0
cli_com_mutex        0x1246be48 unlocked        1         0
cli_com_a_mutex      0x1246be98 unlocked        0         0
cli_lock             0x12400090 unlocked        0         0
List info: size 84, capacity 128, additions 109, removals 25 reallocations 7
Queue Status
Name        Max       Curr      Tot       QFull     Watermark
reaperQ     20        0         4         0         1
persistDb   3000      0         10        0         2
persistDb   3000      0         3         0         2
tshellc     256       0         9922      0         1
Qfsmmain    1000      0         361090    0         75
tshellc     256       0         9965      0         25
Qfsmmedia   1000      0         4988243   0         12
tshellc     256       0         348       0         1
Qfsmclksync 1000      0         415091    0         6
CUILCQ      1         0         0         0         0
tshellc     256       0         0         0         0
tshellc     256       0         0         0         0
tshellc     256       0         0         0         0
Semaphore name      Count
          XPathParse    1
       CallIdTabSema    1
            fsmTrace    1
         bootRequest    0
Task                Type Pri  TID  STACK PTR  %CPU %PROC TIME+     STACK
applstart            OT   0   2367 (nil)  0.0  0.0  0:06.348     0/0
reaperT              OT   0   2426 0x48032000  0.0  0.0  0:00.001  5408/131072
tipc-dev             RR  24   2466 0x48056000  0.1  1.5  0:35.073  6848/131072
UhpiRx               RR  29   2508 0x4807a000  0.4  9.0  3:02.886  5440/131072
persistDb            OT   0   2510 0x4809e000  0.0  0.0  0:00.020  6624/131072
WatchdogThread       OT   0   2511 0x480c2000  0.0  0.1  0:01.565  5776/131072
WatchdogKickerThread OT   0   2512 0x480e6000  0.0  0.1  0:01.321  5216/131072
TimerThread          RR  29   2513 0x4810a000  0.1  1.3  0:31.608  5664/131072
FsmMedia             RR  24   2515 0x48152000  0.5  9.5  3:00.297 10720/131072
FsmMain              OT   0   2514 0x4812e000  0.1  2.9  1:00.912 64704/131072
FsmClksync           RR  24   2516 0x48176000  0.1  1.5  0:35.214  5904/131072
Socket               OT   0   2582 0x4819a000  0.0  0.0  0:00.818  8752/131072
ocspc                OT   0   2583 0x481be000  0.0  0.0  0:00.842  5952/131072
CurlEngine           OT   0   2584 0x48c57000  0.0  0.0  0:00.091  5872/131072
TshelldT             OT   0   2588 0x4949f000  0.0  0.0  0:00.012  7216/131072
snmp                 OT   0   2586 0x4947b000  0.0  0.1  0:02.013  5360/131072
CCP-Register         OT   0   2589 0x494c3000  0.0  0.0  0:00.000  5168/131072
CCP-OutboundConn     OT   0   2591 0x49602000  0.0  0.0  0:00.000  5168/131072
TshelldC             OT   0   2742 0x1248d000  0.0  0.2  0:02.770 23888/131072
TshelldC             OT   0   2643 0x1240a000  3.7 73.6  1:50.681 23888/131072
TshelldC             OT   0   2646 0x1243a000  0.0  0.1  0:00.692 23488/131072
persistDb            OT   0   2647 0x49b44000  0.0  0.0  0:00.006  6624/131072
PBSens               RR  19   2718 0x4a056000  0.0  0.0  0:00.000  5568/131072
IRSens               RR  19   2720 0x4a079000  0.0  0.0  0:00.001  5472/131072
TshelldC             OT   0   2754 0x124b0000  0.0  0.0  0:00.002 17136/131072
TshelldC             OT   0   2766 0x124d3000  0.0  0.0  0:00.390 18720/131072
TshelldC             OT   0  14317 0x124f6000  0.0  0.1  0:00.342 24112/131072
Cpu:  5.0%proc,  4.5%other, 90.6%idle       Total time: 10:56.466
Sorry, this function is not implemented yet.
Hello Danny - Thank you for your information however, I was not able to execute the sys-rtos command from the admin-cli or from root.  I searched the filesystem to see if perhaps there was a script that provided this command but came up empty handed.  Can you provide additional details on how to execute the utility?
Thanks in advance,
-Andrew
Martin - Thank you for this information.  I completely forgot about getting into the codec via root and using the procps package of utilities.  Thanks for the reminder!  :-)  I think I will ask of Cisco for an enhancement bug to be filled for these endpoints however, I think there is a big push to get this information from the endpoints through Prime Collaboration opposed to 3rd party software.  I'll give it a go.  Thanks again for your response!
-Andrew
