Pause in URI speed dial
Lee Saldanha
Hello. We have an SX20 for which we want to create a speed dial to the Blue Jeans service. Once the BJN service answers, we need to enter conference number then # then leader PIN then # again.
I have tried the below strings and none worked - the call to Blue Jeans was answered, but additional characters were never sent. Can you please confirm how to use a pause in speed dial?
987654321,,,,,12345#,,,,,54321#
987654321ppppp12345#ppppp54321#
987654321PPPPP12345#PPPPP54321#
Can't is a hard word to say, I would think of a couple of ways how it could be implemented,
but its all propitiatory, so not a good idea anyhow ,-)
As you said yourself Patrick, the Codian style MCUs support that. Also MXP endpoint,
at least for ISDN.
Lee: If this is a critical point for you, file a feature request to Cisco,
though this would either take a lot of time or will never happen.
Or check with some control panel company which can offer you something like that.
If you have some programming motivation you could also do something like that with a
raspberry pi and the API of the endpoint.
An other option is to ask blue jeans if they could support to populate these values in
the dialed URI or find some other MCU provider.
Many options ;-)
Patrick Sparkman
Endpoints can't and don't know how to handle the dialing of PINs or using DTMF tones when they're incorporated into the dial string, unlike infrastructure devices such as an MCU.  You'll just have to wait for it to connect, and enter the PIN number yourself manually using DTMF tones.
at least for ISDN.
Many options ;-)
Lee Saldanha
Thank you for the explanation, Martin! As you mentioned, raising an enhancement request with Cisco might be more difficult, so I believe I will check with Blue Jeans if something can be done on their side.
