03-01-2005 09:48 AM - edited 03-17-2019 08:23 PM
hi,
We Have a cisco 2610XM with CCME24 and 4 Bri
Can You help us please
Building configuration...
Current configuration : 4446 bytes
version 12.3
hostname TOIP
boot-start-marker
boot-end-marker
memory-size iomem 10
clock timezone pst 1
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip cef
ip dhcp pool telephony
network 192.168.0.0 255.255.255.0
default-router 192.168.0.200
option 150 ip 192.168.0.200
domain-name acscom.biz
no ftp-server write-enable
isdn switch-type vn3
voice-card 1
codec complexity high
dsp services dspfarm
voice service voip
allow-connections h323 to sip
sip
header-passing
registrar server
voice class codec 1
codec preference 1 g729br8
codec preference 2 g729r8
codec preference 3 g711alaw
codec preference 4 g711ulaw
interface FastEthernet0/0
ip address 192.168.0.200 255.255.255.0
speed 100
half-duplex
interface BRI1/0
no ip address
isdn switch-type basic-net3
isdn overlap-receiving
isdn twait-disable
isdn incoming-voice voice
isdn static-tei 0
isdn skipsend-idverify
interface BRI1/1
no ip address
isdn twait-disable
isdn static-tei 0
interface BRI1/2
no ip address
isdn twait-disable
isdn static-tei 0
interface BRI1/3
no ip address
isdn twait-disable
isdn static-tei 0
ip classless
ip http server
ip http path flash:
tftp-server flash:P00305000301.bin
tftp-server flash:P00303020214.bin
tftp-server flash:P00305000301.sbn
tftp-server flash:P00403020214.bin
control-plane
voice-port 1/0/0
disc_pi_off
compand-type a-law
cptone FR
voice-port 1/0/1
disc_pi_off
compand-type a-law
cptone FR
voice-port 1/1/0
disc_pi_off
compand-type a-law
cptone FR
voice-port 1/1/1
disc_pi_off
compand-type a-law
cptone FR
dial-peer voice 1 pots
translation-profile incoming append-in
preference 1
destination-pattern 0.T
direct-inward-dial
port 1/0/0
forward-digits all
dial-peer voice 2 pots
translation-profile incoming apend-in
preference 2
direct-inward-dial
port 1/0/1
forward-digits all
dial-peer voice 3 pots
preference 3
direct-inward-dial
port 1/1/0
forward-digits all
dial-peer voice 4 pots
preference 4
direct-inward-dial
port 1/1/1
forward-digits all
telephony-service
load 7910 P00403020214
load 7960-7940 P00305000301
max-ephones 36
max-dn 144
ip source-address 192.168.0.200 port 2000
time-format 24
auto assign 1 to 36
system message TOIP CISCO
user-locale FR
network-locale FR
create cnf-files version-stamp 7960 Feb 21 2005 14:35:22
dialplan-pattern 1 5.. extension-length 3
keepalive 45
max-conferences 4
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 0.T
ephone-dn 1
number 516
name fred
ephone-dn 2
number 515
name david
ephone 1
after-hour exempt
username "david" password *******
mac-address 0012.D940.D75E
type 7940
button 1:2
ephone 2
username "fred" password ********
mac-address 0012.43B7.3EE6
type 7960
button 1:1
line con 0
line aux 0
line vty 0 4
login local
end
03-03-2005 09:36 AM
I'm sure we can - what is your problem?
Aaron
03-03-2005 09:51 PM
the conf is well ?
because have don't call
03-30-2005 01:14 AM
the configuration is normally ok, but you do not need to configure the different "preference" parameters in the dial-peers.
the second on is that you do not need the "voice service voip", because there are no dial-peers to sip peers or h.323 servers.
If you need more assistance, send the problem (outgouing, incoming, dial-tone, reorder-tone, etc.) to the forum.
greetings
Michael
