Speaktrack60 Firmware upgrade fail after RoomKit PRO firmware upgrade
mohdshajan
we upgraded the firmware of the Room Kit PRO to the latest 9.13 version, however the speakertack60 firmware failed and shows the error as attached.
Any idea how to fix this? It says "Connected peripheral has incorrect software version"
Wayne DeNardi
How did you upgrade the endpoint, did you do it via CUCM, or TMS, or the Web Interface?   Depending on how you did it, the reason it didn't upgrade fully may be different.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
