SX10 call type scenario
Hi all,
does anyone know if the SX10 need a sip registar (CUCM or VCS) to do any call?
for example I my customer need only 2 SX10,  does he need a also a cucm or vcs for do  a call between them?
otherwise, can I do a call between them only with ip address without any sip registar?   like 2 sx20 ..
thanks in advance,
Carlo
32 Replies 32
davidhouska
Hi Carlo,
I just tested SX10 yesterday without CUCM or VCS registration and point-to-point calls inside LAN are working fine...
So you just dial IP addresses same way as you dial it from not registered C-series or MXP series codec.
I did not tested calls through firewall to public IPs but I guess the behaviour will be same as SX20 etc.
David
soohyung choi
Hl,
This problem is resolved using IP Direct call
Thanks for your help
lmediavilla
I've tested it many times (SX10) without registrar and you can use it to call outside.
No problem at all.
