Tandberg Edge 95 MXP configuration
lesfranco
Hi everyone,
I'm trying to connect 2 Tandberg Edge 95 MXP devices in 2 different offices, New York City and Philadelphia. I'm trying to connect them using an internal ip address mapped to a public ip address in the firewall, using H.323 direct with no gatekeeper. When I try connecting, the connection goes through but after a couple of seconds the connection drops. What changes, if any, do I need to make on the firewalls for the connections to work?
Lester
Hi Lester.
Did you get the solution for that?
I'm passing through the same issue you have passed by with 2 tandberg 95 mxp.
Is there a way that I can make calls by the ip of the endpoint?
Thanks for you attention.
Fabiano
