TMS Booking Serial Events with wrong Timezone
Pollux9575
Hello
Another Problem which i have.
If im booking a Serial Event in TMS  i ll get an Icalendar ics for Outlook with (UTC +01:00) West Africa  but the correct Systemtime TMS & Server will be (GMT +02:00) Amsterdam, .... So the Serial Event ll appear wrong in the Outlook calendar.
I ve checked also the TMS-User which is also on (GMT +02:00).
Any Idea where i can locate the (UTC +01:00) . TMS Version is on 13.2.1
Thanks in advance
BR
Alex
aborodai
Amsterdam timezone is UTC+1, TMS get this data from Windows server, so in your case it should be UTC+1.
You can see that from screenshot:
Best Regards,
Artem Borodai
there is a slight difference between that two mentioned time zones, the daylight saving hours.
The problem is that Amsterdam (normally UTC+1) has between March and October a daylight saving hour (UTC+2).
West Africa has the whole year (UTC+1), except of Namibia.
The question is why choose the TMS, when creating a seral event, a time zone that is nowhere set. Server, TMS and TMS-User is set to Amsterdam (UTC+1).
Best regards,
Rainer
