02-20-2013 09:00 AM - edited 03-18-2019 12:37 AM
Following Scenario, have at TMS Jabber Users configured.
If I setup a phone book with source "Cisco TMS Provisioning Directory" and specify that Jabber users I can see at "View Contacts" H.323 and SIP Protocol for contacting those Jabber users.
How can I specify preferred protocol and how can I enable only one of those protocols?
02-21-2013 06:45 AM
I'm aware of Java High Load errors with Findme, so its not enabled
(It would be good to disabel video address pattern if FM is disabled)
Will do as you suggest and start from scratch...
Thanks guys
02-21-2013 06:55 AM
Hopefully the last question
At Systems -> Provisiong -> Devices
there is a list with all Movi users that are registers once in the past. All devices are registerd with a video address pattern. Is it good to delete them also?
(Don't need any further information of this page).
02-21-2013 07:03 AM
I would delete them since you do want to get to a 'scratch' device list and don't particularly want these in the tmspe db 'muddying up' your PB Source since your now importing them to your PB Source.
/Dale
02-21-2013 08:31 AM
Deleted the Devices list - but after signing in again I can see a valid video address pattern.
Whats wrong?
Juergen
02-21-2013 10:23 AM
Hi jurgen
Its a bug in the vcs that it does not delete the device list (TMS does but the vcs pushes it back, this is also related to the device import bug which causes the high cpu in TMS). It should be fixed in X8.
/Magnus
02-21-2013 10:53 AM
Should/can I delete the device list at the VCS also?
Or is this not a problem with the video address pattern?
Juergen
Sent from Cisco Technical Support Android App
