VCS Connection Time / Not Finding SIP Registered EP
John Faltys
VCS 7.2.2
Dialing a SIP URI from a SIP Endpoint, the VCS does the appropriate search.
It looks for the URI and does a SIP lookup first (which it does not find although it is registered)
Then it times out, and finds it via H.323.
The Endpoint that is being dialed is dual registered with the same name.
1. I checked the registrations, and it looks fine. This particular EP is registered to a VCS Express.
2. I checked the SIP search and it matches the SIP registration (but does not find it).
3. VCS has both TCP and UDP enabled.  Is this the reason that it might not find the SIP endpoint?
Below is part of the search. And below that is the SIP registration.
Search (131)
    State: Completed
    Found: True
    Type: SIP (INVITE)
    CallRouted: True
    CallSerial Number: d517c746-df4b-11e2-9854-0010f31ed420
Destination (1)
        Alias (1)
            Type: Url
            Origin: Unknown
            Value: sip:fed.adm.101@acme.com
    StartTime: 2013-06-27 10:05:56
    Duration: 36.8
SearchRule (2)
                        Name: Local zone Any Rule
                        Zone (1)
                            Type: Local
                            Protocol: SIP
                            Found: False
                            Reason: Request Timeout
                            Duration: 32.01
                            Gatekeeper (1)
                                Address: 1xx.1xx.1xx.xx:0
                                Alias (1)
                                    Type: H323Id
                                    Origin: Unknown
                                    Value: fed.adm.101@acme.com
                        Zone (2)
                            Type: Local
                            Protocol: H323
                            Found: True
                            StartTime: 2013-06-27 10:06:28
                            Duration: 4.5
                            Gatekeeper (1)
                                Alias (1)
                                    Type: H323Id
                                    Origin: Unknown
SIP Reg
Status
Active    true
Name    fed.adm.101@acme.com
Protocol    SIP
Type    SIP UA
Authenticated    True
Node    DefaultSubZone
Vendor information    TANDBERG/68 (L6.1)
Serial number    85615b54-dec9-11e2-91bb-0010f31ed420
Creation time    2013-06-26 18:33:08
Duration    15 hours 37 minutes 6 seconds
AOR    fed.adm.101@acme.com
Contact    sip:fed.adm.101@198.72.197.193:5060
Martin Koch
Hi John, how are you?
SIP on the 150 MXP sucks. You either just want to disable sip and only use it on 323.
Also some other calls (even with h323) which the 150 did not like.
So the best option is to replace it with something different, if you still have some e20
thats ok, jabbervideo is an option or ex60/90.
Btw, the search rule shows that it was found, but the request send to it was not properly replied on so it timed out.
Please rate the answer and mark the thread as red!
Martin
Martin Koch
Martin
