Webex Codec Pro and Crestron Control
zwright01
I am controlling an SX-80 via crestron using a cisco room devices 3.0 module that accomplishes most tasks required. I do however get stuck when dialing to webex numbers such as zach@XXX.webex.com. The sx80 screen shows a question "Are you the host?" and I am unable to find a way to answer this question via the api ce9.6 doc. The closest thing I can find is
xCommand UserInterface OSD Key Click Key: Key
where Key = 0/1/2/3/4/5/6/7/8/9/C/Call/Disconnect/Down/F1/F2/F3/F4/F5/Grab/Home/Layout/Left/
Mute/MuteMic/Ok/PhoneBook/Presentation/Right/Selfview/Square/SrcAux/SrcCamera/
SrcDocCam/SrcPc/SrcVcr/Star/Up/VolumeDown/VolumeUp/ZoomIn/ZoomOut/+/-
The sx-80 wil take that command with Key = Ok and it makes a ping like it took the command but the prompt "Are you the host" stays up and the webex call does not get placed and eventually times out. What response does the SX-80 want?
0 Replies 0
