xcommand web view
TkOo
Does anyone knew what can this command below do?
xcommand UserInterface WebView
This command shows "couldn't open {{some title}}."
Is this caused by network configuration or ...
Recently I changed Roomkit registration method from UCM to Webex cloud registration.
Thus OS has changed from CE 9.x.x to RoomOS, I've been messing around with CLI and found some new commands there.
There doesn't seem any documentation on Room OS or something like admin guide anywhere so far.
The "WebView" is to use your On-Prem endpoint for Digital Signage when it's not being otherwise used.  It allows you to specify a URL which will be displayed by the endpoint on the screen instead of the usual half-awake screen.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
