Audit log for TMS? How to determine when/how an endpoint was deleted?
ROGER MCGUIRE
Is there any sort of audit log in TMS that will show when/how/who deleted an endpoint (C-series, EX90, etc) from the TMS system?
Magnus Ohm
You can enable the TMS audit log under General Settings. The audit log is not enabled by default.
This is the information you get in the audit log when you delete (purge) a system from TMS.
/Magnus
