Cisco SX10 Standalone Capabilities
clarencemaseko
Going through the SX10 data sheet I saw that it has support for the H.323 protocol so I was wondering if this device could be used as standalone just like we do with SX20.
I want to setup just 2 video rooms for the same organization so standalone will be more cost effective.
Thanks in advance
Magnus Ohm
Yes you can!
You can Use SIP (with "Listen Port: On") as well for standalone, you don´t -have- to use H323.
/Magnus
Patrick Sparkman
Take a look at Vivek's reply in sx20-as-standalone, the configuration is the same for the SX10 as it is with the SX20, be sure that you're running CE8.2 and later which supports H323.  Take note that if you deploy the endpoint using a public IP address, recommend you put it behind your organization's firewall and restrict all incoming traffic to specific IPs you want to conference with. If you do not, the endpoint will be scanned by external systems hosted on the internet, and you'll start to begin to receive toll-fraud calls.
