How to Manually Change TMS System ID?
adam.watts1
I know this is a long shot, but is it possible to manually change the TMS System ID?
When replacing a system, we had someone accidently purge and replace rather than just do a simple replace. Now the room is not bookable through Outlook since the current room has a new TMS System ID and Exchange is looking for the old TMS System ID.
Zac Colton
Reconfigure TMSXE with the correct TMS system. Changing the ID within TMS is not possible.
Thanks you Zachary , it worked for me :) +5
