Schedule CMS Meeting through TMS without including a Codec
Matthew S
I'm using CMS 2.3 and TMS 15.6.1 and was wondering if there is a way to Schedule a CMS meeting through TMS or Smart Scheduler without including a codec?
I have everything set up with through this guide: https://www.cisco.com/c/en/us/support/docs/conferencing/meeting-server/212298-cisco-meeting-server-acano-tms-integ.html
Everything works fine if I include the CMS participant and my personal DX80 but if I want just include CMS because I don't know what conference room I may be using in the future or just want remote users to participate without using a codec the meeting will establish but not save a TMS Space so my email will display no meeting instructions.
Just wondering if this is possible or maybe a bug with the current solution.
Matt
2 Accepted Solutions
Zac Colton
Just add dial-in participants to start with.
Patrick Sparkman
Using the admin scheduler or Smart Scheduler, have you tried to just add call-in participants only?
7 Replies 7
Zac Colton
Looks like I have to select both Video Call-In SIP and Audio Only Call-in - Sip if I want the bridge to be created.
If I just did Video Call-In SIP it wont create and just Audio Only Call-In - Sip it wont create...
Add 2 SIP dialing. One participant is not a meeting, so a bridge won’t be selected
That makes too much sense... Thanks for the help.
Patrick Sparkman
Looks like I needed to do both Audio only and Video call in to get it to work... guess that's just the way it is.
Correct, in order for a conference bridge to be allocated, you must have a minimum of two participants. So just need to add as many Video Clal-in SIP participants as you expect to have in the conference, or simply add the minimum requirement of 2.
