YDK 0.8.6.3 C++RPM
Mike Fisher
I am looking for a RPM of the latest ydk for C++.  I looked on https://devhub.cisco.com/ui/native/rpm-ydk/ but the latest RPM I could find is libydk-0.8.5-1.x86_64.rpm  Could someone please point me to an x86_64 RPM of 0.8.6.3 (preferably for RH8)  built from the github repository https://github.com/CiscoDevNet/ydk-gen
ygorelik
You can build the core and gnmi packages yourself after you successfully compile and install the libraries. Simply go to the build directory and issue command:
sudo make package
That should create the RPM or Debian package based on the system.
ygorelik
sudo make package
@ygorelik   Thank you for the reply.  I was able to create the RPM.  However, when I attempted to install the rpm into a RH8 docker container with no internet connection, it attempted to run a curl command to the remote site mirrors.fedoraproject.org.  Is there a way to build the RPM, such that it contains all of the dependencies, with no need to access the internet at install time?
I am not aware of such approach. If you look at the older versions, like 0.8.0, installation, you will find that it requires to install some dependencies before installing rpm package.
