Orf Gelbrich
Task NameCreate VLANs on Selectable Network Devices
DescriptionCreate VLANs on Selectable Network Devices
Prerequisites
  1. Tested on 5.2.0.2
CategoryWorkflow (and tasks)
ComponentsCreate VLANs on Selectable Network Devices.
  1. Log in to UCS Director as a user that has "system-admin" privileges.
  2. Navigate to "Policies-->Orchestration" and click on "Import".
  3. Click "Browse" and navigate to the location on your computer where the .WFD file resides. Choose the .WFD file and click "Open".
  4. Click "Upload" and then "OK" once the file upload is completed. Then click "Next".
  5. Click the "Select" button next to "Import Workflows". Click the "Check All" button to check all checkboxes and then the "Select" button.
  6. Click "Submit".
  7. A new folder should appear in "Policies-->Orchestration" that contains the imported workflow.
Inspired by work done by David Lefebvre.
The workflow properties need to be updated for the network device and the e-mail address:
Select the admin input:
The network devices that are currently visible by UCSD will show:
The workflow:
User input at runtime:
The execution of the workflow looping through the selected network devices:
The roll back is indicating 2 devices were touched which were selected in the admin over ride:
Toivo Voll
Fails validation with "Missing User Admin Input for: LoopVarNetworkingDevice"?
Orf Gelbrich
Did you re-link it in the start loop task?
Toivo Voll
I did do the same to it as your instructions suggested for the other two properties (the first screen shot), and that seems to have fixed it.
Orf Gelbrich
Glad it worked.
Orf Gelbrich
Check out UCS Director Workflow INDEX<https://communities.cisco.com/docs/DOC-56419> on Cisco Communities (External)
