Orf Gelbrich
Task NameChange of time out for Powershell
Description
Prerequisites
Tested on UCSD 5.4 / 6.5
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  8. Click "Submit".
Thank you Alejandro Madurga Ainoza
Powershell agent have three different timeouts:
     One for Idle time
     One per command execution
     One per session
Find attached a custom tasks that behaves similar to the OOTB but it allows you to enter any amount of minutes.
Tested with 65 mins and it worked (I set the timeout to 70 mins, and the script slept for 65 mins):
ekleditzpge
Community Member
There seems to be an issue with this in 6.5, the task errors with:
ReferenceError: 'PSAgentAPI' is not defined in <eval> at line number 79, selectedContext=<None>
ppenmeth
Level 2
Level 2
Hi Erich, Can you try 'Execute Native Powershell Command' task instead in UCSD 6.5 ? Thanks, Phani
ekleditzpge
Community Member
Hi Phani,
Cant do that, it still has a 60 min timeout.  We have some scripts that can run longer. Thats why we use this one.
ppenmeth
Level 2
Level 2
Hi Erich, Please try the updated WF (CustomPSTimeout-UCSD65.wfdx) that is uploaded to this community document. Thanks, Phani
ekleditzpge
Community Member
Looks great! Thanks!
