Orf Gelbrich
Task Name
MAC addres COnversion Example.  Convert : to -
Description
Prerequisites
Tested on UCSD 5.4.0.3
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  8. Click "Submit".
Inspired by Mark Smith
The Workflow:
The Execution:
The Run:
The Code:
var Macstr = input.InputMac;
logger.addInfo("InputString is: "+Macstr);
// var str ="00:25:B5:00:0A:04"
var outputstr = Macstr.replace(/:/g,"-");
logger.addInfo("OutputString is: "+outputstr);
output.OutputMac = outputstr;
David Hild
Level 11
Level 11
Could someone please briefly explain what problem this solves, or why this is necessary?
Thank you in advance.
Orf Gelbrich
I am not sure of the problem either, but I was asked on how to convert a MAC address of this format
     00:25:B5:00:0A:04
to this format
     00-25-B5-00-0A-04
I have seen here and there (storage,?) this format.  Yes it seems odd, but one of my colleges needed to convert the MAC address from one format to another.
Further I thought it a a very good example on hoe to convert or eliminate certain strings from with in a string.  This could also be used in the custom task to convert the variable type.  From lets say UCSD_MAC_ADDRESS_TYPE to generic_Text.
David Hild
Level 11
Level 11
Ah, I see it now. I was trying to see how the actual address was changing (which it wasn't, hence the confusion), but it's the FORMAT that changed. Yes indeed, handy tool, that. Thanks for the explanation.
