Orf Gelbrich
Task Name
XtremIO Example
Description
  1. Change the user of a running workflow
Prerequisites
  1. Tested on 5.3.1
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  1. userid to change to
OutputInstructions for Regular Workflow Use:
  8. Click "Submit".
Thank you Mark Smith
Color:
Custom Tasks to do XtremIO storage provisioning using the XtremIO Rest API for the versions listed in the described document. Developed all Tasks needed for a bare metal provisioning workflow using boot from SAN. Attached is the workflow.
Create new tasks by cloning one of the existing tasks, adding any new input/output parameters and changing the JSON structure to match the new API call.
This document was the basis of the work:
     docu56460_XtremIO-3.0.1,-3.0.2-and-3.0.3-Storage-Array-RESTful-API-Guide.pdf
     This can be obtained on the EMC site for download.
The workflows included:
The workflow to Create a Volume:
naresh.sankepalli
Community Member
Has anyone created a workflow to automatically select ESX cluster hosts and map lun from Xtremio?  I think built in task lets you map only one host at a time.
Orf Gelbrich
Take a look at this....
https://communities.cisco.com/docs/DOC-56419
Orf Gelbrich
Check out UCS Director Workflow INDEX<https://communities.cisco.com/docs/DOC-56419> on Cisco Communities Site
Orf Gelbrich
the picture I pasted did not come through there is the link
VMware ESX Cluster Node Name Determination.
