Task Name | XtremIO Example |
Description | - Change the user of a running workflow
Prerequisites | - Tested on 5.3.1
Category | Workflow |
Components | vSphere 5.x |
User Inputs | - userid to change to
Output | Instructions for Regular Workflow Use: |
- Download the attached .ZIP file below to your computer. *Remember the location of the saved file on your computer.
- Unzip the file on your computer. Should end up with a .WFD file.
- Log in to UCS Director as a user that has "system-admin" privileges.
- Navigate to "Policies-->Orchestration" and click on "Import".
- Click "Browse" and navigate to the location on your computer where the .WFD file resides. Choose the .WFD file and click "Open".
- Click "Upload" and then "OK" once the file upload is completed. Then click "Next".
- Click the "Select" button next to "Import Workflows". Click the "Check All" button to check all checkboxes and then the "Select" button.
- Click "Submit".
- A new folder should appear in "Policies-->Orchestration" that contains the imported workflow. You will now need to update the included tasks with information about the specific environment.
Thank you Mark Smith
Color:
Custom Tasks to do XtremIO storage provisioning using the XtremIO Rest API for the versions listed in the described document. Developed all Tasks needed for a bare metal provisioning workflow using boot from SAN. Attached is the workflow.
Create new tasks by cloning one of the existing tasks, adding any new input/output parameters and changing the JSON structure to match the new API call.
This document was the basis of the work:
docu56460_XtremIO-3.0.1,-3.0.2-and-3.0.3-Storage-Array-RESTful-API-Guide.pdf
This can be obtained on the EMC site for download.
The workflows included:
The workflow to Create a Volume:
