a basic question about unity
ciscoforum
Does unity randomly pickup voice mail port to answer incoming call or use the port in order? It seems there is no pattern.Thanks.
eschulz
With the exception of SIP Proxy integrations, Unity picks up on the voice mail port which recieves the call. I.e. if Unity detects an incoming call ringing on port 7 then it will pickup and answer port 7. It is the phone system that decides which voice mail port the call is sent to. Unity has no control over this.
I mention SIP Proxy as an exception because with this the concept of 'ports' is a bit different.
Eric
if unity integrate with CCM, is there way CCM can control the ports in sequence? like circular or first available? Thanks
As far as I know, CCM will send to the first unused port in sequence from the top-down. MWI, as I understand it is a Bottom up, although I'm a little fuzzy on that.
