AA Issue
Austin3:16
Hello Team,
i have an issue when someone call The AA from PSTN the call is forwarded directly to operator (no greeting) when i have collect the log i see that the call manager send "181 call is being forwarded". to CUBE.
Please need your Support.
Ratheesh Kumar
Hi there
Can you elaborate more here. Where exactly the call is failing ? If you replace the number of AA with any internal ext, does that work
181 call is being forwarded simply means the call is forwarded to a global or a specific dial peer
Hope this Helps
Cheers
Rath!
***Please rate helpful posts and if applicable mark "Accept as a Solution"***
The call fail when calling the AA from external, no i have set incoming rule on gateway point to AA, ill change that and ill be back to you
Austin3:16
log file attached of the vgw
