account is locked on Unity Connection 7.1.3 webpage
rachelau_2005
All my accounts are locked out when I tried to log on to the unity connection webpage ( via web interface).  I am still able to access the unity server via ssh using my administrator account
How can I unlock the unity connection web account ( cuadmin)?
Kind regards
Rachel
David Hailey
Rachel,
I mocked up the following in a lab:
user alias = cuadmin
account = locked
Login as admin via SSH.  Enter the following command:
utils cuc reset password
You will be prompted to enter the new password twice.
In my case, I entered "utils cuc reset password cuadmin" and then entered a new password (twice).
Afterwards, I am able to login using the cuadmin account and the CUC user display no longer indicates the account is locked.
Should be enough to get you in.
Hailey
Please rate helpful posts!
David Hailey
Rachel,
account = locked
Hailey
Thank you so much for your help, its working now, thanks a lot
Kind regards
Rachel
