Adding caller id's to incoming mobile phone calls.
swhitworth
We have a number of mobile workers who call into our CUCM 7.1.5 system after visits and it would be helpful if their mobile numbers could be resolved to names.  Is there any way of doing this.
Many thanks,
Silas
keglass
Level 7
Level 7
Silas,
Have you checked out this CUCM 7.X document about Cisco Mobility Applications?
Cisco Unified Communications SRND Based on Cisco Unified Communications Manager 7.x - Cisco Mobility Applications [Cisc…
If you still have questions, I recommend you also post to the Cisco Support Community for additional information.
Cisco Technical Support Forum
Hope that helps.
Kelli Glass
Moderator for the Cisco Collaboration Community
