Adding same remote destination to 2 different RDP's
m.batts
Level 4
Level 4
Hi , i have 2 different remote destination profiles assigned to  2 particular numbers.  I want the same remote destination to be part of both RDP's . Obviously it doesn;t allow that . I was wandering if there was a workaround or not . Using CUCM 11.5
m.batts
Level 4
Level 4
Please ignore . I figured it out . You need to add the numbers to the same RDP .
