Additional Users with voicemail on Unity Connection (on CUCM BE)?
ryabutler
This should be a quick and easy one, but I want to confirm something that I'm not confident about.
The old part number I remember using before related to Unity Connection in a CUCM BE solution is no longer available.
I have CUCM BE 8.  On Unity Connection I need to purchase additional "Users with voice mailboxes".  We had 65 and all are used.
Can I simply purchase, L-UNITYCN8-USR (per user), to get additional users for voicemail?
Thank you!
-rya
Jonathan Schulenberg
Yes assuming you're not under Workspace licensing and want to add *only* Unity Connection entitlement. Don't forget to add ESW/UCSS numbers to keep coverage up to date. If you're using Workspace licensing you would likely want to order a standard seat license instead.
There are BE-specific SKUs but they do the same thing.
LIC-BE5K-VM-BAS - Base mailbox.
LIC-BE5K-BAS2ADV - Upgrade to fully functional mailbox.
Ordering Guide for Cisco Business Edition 5000 and 6000 v8.6 (Partners Only)
No we are using Traditional Licensing with our CUCM BE 8 system.
So based on your response, that part number will work on CUCM BE 8.0.3 for adding additional voicemail account right?
Thank you!
-rya
